LVDT sensor messung
06.02.2018, 10:36
Labview_pr Offline
2017
LVDT sensor messung
I have a new project, to measure the displacement using LVDT sensors.
I am using NI 9237 module with the cDAQ9184, and for the LVDT is from HBM.
Here I am asking if someone has an idea, how to connect the sensor to the 9237 and calibrate it.
Any suggestion will be very appreciated Smile
Thank you in advance..
06.02.2018, 11:02
RE: LVDT sensor messung
Hi pr,
Zitat:how to connect the sensor to the 9237
See the NI9237 datasheet, pages 4 and 5…
For the LVDT sensor you have to check its manual!
Zitat:and calibrate it.
Calibration is done by the manufacturer…
07.02.2018, 13:32 (Dieser Beitrag wurde zuletzt bearbeitet: 07.02.2018 13:49 von HVo.)
HVo Offline
Erbsenzähler
>3.1 :)
1992
A classical LVDT will need a AC (bridge) exitation.
All HBM LVDT sensors I knew (and I started to collect them) are:
-Quite old Smile
-without DC output.
Your 9237 only supports DC-excitation.
However, you can try the soundcard headphone out to ecxite with 1kHz sine and the stereo line-in to read the bridge output and the exciter-voltage (maybe after a voltage divider). The voltage ratio is proportional to the LVDT core displacement. (try tone detection on both signals)
Or hunt for a an old AC bridge amplifier...
What sensor(s) do you have? What is your application?
(If you really have an old HBM LVDT sensor, I guess you want to reanimate some old equipment)
HBM stoppet LVDT production shortly after going into the strain-gauge production...
Classical length sensors can be calibrated with a micrometer, gauge blocks down to laser interferrometer... use the best reference you can grap Wink
According to the VIM (and Wikipedia) anyone can do a calibration, not only the manufactor.... otherwise I would be out of business Big Grin
Tschuess
Henrik
'The number you have dialed is imaginary, please turn your phone 90° and dial again....'
  Sensirion I2C Sensor auslesen Max21 1 3.927 09.09.2022 10:38
  Entfernung messen mit HC-SR04 Sensor Unplugged 4 6.745 30.12.2018 17:44
Letzter Beitrag: Unplugged
  Dauerlauf Zylinder und Sensor ck1984 8 8.656 18.07.2016 09:25
Letzter Beitrag: ck1984
  Energiezählung mittels Ferraris Sensor manu986 3 6.557 14.06.2016 19:37
  Druckerfassung über Sensor und NI 8452 Alighieri 10 12.111 09.03.2015 11:56
Letzter Beitrag: Alighieri
Smile NI cDAQ9174 + NI9401 - Drehzahlmessung mit Hall-Sensor vescon 4 9.601 16.01.2014 20:59
