Cannot load VI in teststand.
20.02.2026, 12:52
Vindsan Offline
Hi, I have a sequence where there is a VI, and initially, it's all OK, like this.
But after running the sequence, the VI is lost or cannot be loaded and is like this
I have to restart teststand to run the sequence again. Why is this happening. Thank you.
20.02.2026, 16:31 (Dieser Beitrag wurde zuletzt bearbeitet: 20.02.2026 16:32 von GerdW.)
RE: Cannot load VI in teststand.
Hi Vindsan,
generic recommendation: as this is the German LabVIEW board the discussions are usually held in German. For discussions in English you could use the NI Forum
Anyway:
- Why don't you create a packed library (lvlibp) from your LabVIEW VIs? This is the common recommendation when calling LabVIEW VIs from TestStand!
- Do you use LV2017 with TestStand 2017? (Mind to update your user profile?)
- Is that Config VI even runnable from the RunTimeEngine (as written in the error message?
24.02.2026, 12:59
Vindsan Offline
This is part of a big project that was created before me, i just joined the company and has to work on this and i cant make such big changes. But for future when I am working on my own projects I will use .lvlibp.
I use LV2017 with teststand 2016.
The config VI is runnable, as I said, I run it one time, it works and then the error appears which is what i dont understand. Then I have to close teststand and run again.
  Cannot include teststand runtime whie creating installer in teststand deployement uti Vindsan 3 2.167 30.01.2026 13:42
  TestStand StationGlobals automatisch erstellen angry_Nameless 1 4.770 19.06.2020 13:45
Letzter Beitrag: Morpheus
  Teststand StationGlobals importieren Felix777 1 5.508 30.01.2019 10:13
Letzter Beitrag: Freddy
  Literatur und Video-Tutorials zu TestStand Felix777 4 8.523 02.07.2017 10:01
Letzter Beitrag: Felix777
  NI - Teststand Testprogramm Papafirefest 1 6.454 18.11.2016 12:52
  Detailed Help von VIs nicht in TestStand verfügbar? balze 0 4.975 24.02.2016 16:40
Letzter Beitrag: balze
