I am trying to create a installer in teststand deployement utility 2016 just for learning purposes, its a simple sequence file with one simple VI. The sequence file is generated in 2016 and .VI is generated in 2017. I have attached it here, its not important. What is important is here what i am trying to do in the deployement utility. In deployement utility undeo installer options I selected Teststand Runtime 2016, but the problem is when I trying to build, i am getting this, which is shown in Picture1.
Then it asks for the path to NI Teststand 2016 SP1 (32-bit). Is this the actual NI Teststand? If yes I would give it the folder, here you can only select folder and not the file. This is shown in Picture2
and I give it the path in Bin. When I select the folder this pops up, which is shown in Picture3.
But in bin, the Teststand application is not saved as Teststand, it is saved as SeqEdit.exe. Is this the problem it cant find it. If yes how can I change it to select a file instead of just the folder or what should i do to solve this issue. Thank you.
