RefNum
08.09.2004, 13:34
Sapphira Offline
RefNum
kann mir jemand erklären, was ein "RefNum" ist?, welche Funktion es hat?, und welchen Datentyp?
Sapphira
16.09.2004, 15:16
Irene He Offline
RefNum
"RefNum" itself is an integer, but it means many different things. It could be the pointer to a data structure or it could be simply just an internal number created by NI for certain functions. You get "RefNum" when you open a file, or create a queue etc. Different way created "RefNum" should not be used mixed, for example you can not use the RefNum that you get from opening a file to pass into a queue vi. What exactly do you want to do?
Irene
http://www.hytekautomation.com
LabVIEW camera and video toolkit provider
24.09.2004, 08:36
Sapphira Offline
RefNum
Hello,
For creating a RefNum from a c++.net dll it only works with the constructur node, or is there another posibility?
Sapphira
  typedef refnum's to string and back GT123 8 7.650 09.09.2016 14:25
Letzter Beitrag: GT123
  SubVi - Referenz Refnum vescon 2 6.290 01.10.2014 08:44
Letzter Beitrag: vescon
  Refnum error mathew086 2 4.571 27.08.2012 09:58
  Fehler 4801 "invalid task refnum" banman 5 8.105 24.02.2011 09:31
Letzter Beitrag: banman
  Refnum für Cluster erstellen? NafeZ 6 10.994 12.10.2009 17:26
Letzter Beitrag: bikobeko
  Stringwert in Refnum->Array->Cluster->String Indicator.JPG GT123 2 5.781 22.07.2009 08:43
