How to increase array element on FPGA
18.11.2011, 13:29
RobertR Offline
11.0
Hi all,
I'm quite now to Labview. I used Perl, Ruby, PHP and C before, but I have big problems to get used to work with Labview.
How can I port the following piece of code to my Labview FPGA VI?
There is a given index i and I want to increase the i-th array element. The array was initialized with zeros before.
Code:
array[i] += 1
Best,
Robert[/code]
18.11.2011, 14:12
NWOmason Offline
Simultator
2012.SP1
RE: How to increase array element on FPGA
Hi Robert,
you can use all these array-functions in LabVIEW with FPGA-Module:
Array Functions
http://zone.ni.com/reference/en-XX/help/...y_palette/
(18.11.2011 13:29 )RobertR schrieb:  There is a given index i and I want to increase the i-th array element. The array was initialized with zeros before.
Code:
array[i] += 1
I think the following example code should help you out:
Best regards,
NWO
18.11.2011, 14:20
RobertR Offline
11.0
Thanks a lot!
  Sind Referenzen auf FPGA-Variablen in FPGA vi möglich? Felix777 2 9.287 26.10.2015 20:41
Letzter Beitrag: Felix777
  FPGA-Referenz öffnen: FPGA-VI nicht kompiliert LauraP. 9 15.495 17.03.2015 16:58
Letzter Beitrag: LauraP.
  Array Integration in FPGA phoenics 2 7.572 13.09.2010 09:58
Letzter Beitrag: Martin Heller
